I replaced the Glass Console and the Control Board. When I followed the "End of Service Test Procedures" at step 13, the unit should display "GAS". Nothing happens. Later the range reverts to what looks like normal operation but when I try to use it I get error code F1:E3. I found a web site that listed the code as: [FONT='Arial','sans-serif']F1 - E3[/FONT] [FONT='Arial','sans-serif'] Wiring harness cavity size does not match previously stored value[/FONT] [FONT='Arial','sans-serif'] The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size. [/FONT]
My question is where are the jumpers and how are they set?
I had the same problem getting the code F1:E3. I found out the oven door lock was not all the way in the unlocked/locked position. It is very important to have all relays and switches in the correct position before going through the programing so the new board can do a proper check of all components. This makes the setup go alot quicker. The new board could not tell the door was attached so it through the code F1:E3 to tell me to check the cavity size and jumper settings. After the door lock was in the right position the board was able to read the jumper setting to get the right cavity settings automaticly.
Im having the sajmme problem and i wanted to know if u changed the door lock or did u ever find the jumper wires please let me know i will greatly appritiate it.
