koolrod
#1 Posted : Friday, January 28, 2011 9:21:46 AM(UTC)
koolrod
Water does not enter the wash on any cycle. I will turn the knob and choose a wash cycle and pull the knob. Usually there will be water beginning to enter. The only sound I get is a low hum. The problem happened just after a finished wash. I have replaced the water inlet valve. It did not solve the problem. Please help.
Rodney
sidfink43
#2 Posted : Saturday, January 29, 2011 4:11:16 PM(UTC)
sidfink43
Well, you have gone after the obvious cause, so now you need to check other things. The pressure switch is another obvious problem, as is the door lock, the wiring and the timer.
Use a meter to check continuity, and here is a service manual which should help you with the process.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
koolrod
#3 Posted : Wednesday, February 2, 2011 7:14:54 AM(UTC)
koolrod
I did the troubleshooting and it led me to either the timer or door lock assembly. Is there any further way to check the door lock or timer? Please help.:confused:
sidfink43
#4 Posted : Wednesday, February 2, 2011 9:21:45 AM(UTC)
sidfink43
If you have the service manual you know what we know. The door lock assembly is the likely source of the problem, I would replace it and see if that fixes things.
If you buy from this site and the part does not repair the problem you can return it, see the returns policy for conditions.
