I just bought a washing machine used not even two hours ago, i hooked it up and as soon as i turned the water on, the water started running into the washer without it even turned on! I dont know how old it is all i know is that its a 2 speed 8 cycle whirlpool. I really need help, what can i do to fix it without costly repairs??
A new water valve will fix that problem.
Do you have the model#, should be on the machine when you open the lid.
