jjones651
#1 Posted : Friday, December 5, 2008 11:33:44 AM(UTC)
jjones651
Every couple of years the defrost thermostat goes in my unit. I think it went out again last night. I had the same problem as before, the circulation fan is in-op. I took the thermostat out, by passed the wiring and the fan came on and cooled the unit down. I went to Sears this afternoon to buy a new thermostat, put it in and it appears to be defective. In a round about way my question is should the thermostat have continuity when not installed?
jjones651
#2 Posted : Friday, December 5, 2008 12:20:30 PM(UTC)
jjones651
I looked through the forum and found out that the defrost thermostat has to be cold in order to close. I re-installed it and after about 5 minutes the fan came on.
