mzarahemla
#1 Posted : 14 years ago
mzarahemla
Great Oven....until now. Cleaned the oven like we have in the past. Now looks great but neither element heats up. Convection fan works, light works, front panel works. Consulted the "manual" ...but of no value. Any ideas before I spend my paycheck on repair?
#2 Posted : 14 years ago
Replacement parts for KEBC177KBL0 models | AppliancePartsPros.com
Here is a manual which should be a close match to yours
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6342e2edf7772b6e852573440054cfc6/$FILE/4317418%20Single%20Wall%20Oven.pdf
The first thing to check is the power.
The lights, control panel etc. all run off half the line while the lements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next would be the over heat thermostat, Item 37 in Section 1.
It is not uncommon for these to pop after a self-clean cycle.
Remove power from the unit and the wire to one side of the thermostat.
Then measure it with a meter, should be 0 ohms.
