ktogun
#1 Posted : Tuesday, January 25, 2011 12:32:28 PM(UTC)
ktogun
Views messages in topic : 1
Gene,
I've read everyone's posts about this, and I have the same deal. Freezer works great, makes ice like a champ, freezes everything solid, but the fridge runs at around 48 degrees stable. I pulled the back panel of the freezer off and defrosted the coils and fins with a blow dryer, ran heat into the front plenum, and even shot hot air into what I think is the supply in the fridge next to the freezer temperature dial. I'm going to see what happens, but I'm trying to figure out what parts to order to make this a permanent fix. I've read on here that the defrost timer, thermostat, and element could be the issue. Let me know what you think it is and the part numbers so I can order them from you all. Thanks!!
Kurt
