cn36131
#1 Posted : Monday, January 24, 2011 8:48:29 AM(UTC)
cn36131
Since yesterday the evap fan started making loud clicking noise. Sometimes the fan would start turning for a while and noise stopped. But when I pushed the dispenser arm, the noise came back and the fan stopped again. The freezer is still cooling well but the ice/water dispenser is not working, nothing comes out. Also, whenever I pushed the dispenser arm, the light on the dispenser got dimmed or weakened. Please let me know what need to be changed and part #.
#2 Posted : Monday, January 24, 2011 1:48:45 PM(UTC)
The correction is to replace the evaporator fan motor together with the main control board. Before you order the parts inspect the fan motor wire harness to find if the thermistor is wired into the same plug.
- The fan motor without the thermistor Part number: AP3875639
- The fan motor with the thermistor Part number: AP3191003
