titom
#1 Posted : Wednesday, December 3, 2008 6:36:58 PM(UTC)
titom
:confused: washing machine will dump out water from bottom of machine
kayakcrzy
#2 Posted : Thursday, December 4, 2008 5:00:36 AM(UTC)
kayakcrzy
It is most likely the pump, which is located in the front. You have to take the screws out that hold the control panel down, and flip it back, and then there are 2 brass clips, on the top right corner of the cabinet, and one on the other side. Remove them, and unhook the molex plug for the door switch, and then remove the cabinet. The pump is right up front. Pop of the 2 clips, take the 2 hoses off, and you have it. Tom ApplianceEducator.com
