OLD BOY PAW
#1 Posted : Wednesday, December 3, 2008 3:18:47 PM(UTC)
OLD BOY PAW
:confused: I install a new pressure hose on my pressure switch. Now sometimes the water shut off and sometimes the fill water keeps on filling till it over flows. It was working just fine before i changed the pressure hose it was. What do i have to do to make it work like it should? THANK YOU FOR YOUR HELP
SublimeMasterJW
#2 Posted : Wednesday, December 3, 2008 5:10:19 PM(UTC)
SublimeMasterJW
Blow dat trash out the bottom of the tub so da pressure switch can work all propah. Make sure that hose is tight. Barometric pressure from the tub as dat water rises cause dat switch to act and kick the motor on. No pressure no wash.. End of story. Tight hose with no trash in it is the key Kimosabe.:D
