kurty_blaze
#1 Posted : Wednesday, December 3, 2008 2:28:30 PM(UTC)
kurty_blaze
I have a Admiral 26cuft. side by side model #LSD2615HEW, about a week ago both the fridge and freezer sides stopped cooling. Although the bottom of the unit is cold, i had a couple tri tips and some chicken in the bottom of my freezer and it is still frozen. Yet the rest of the freezer is warm, there is no ice build up.
please help!
libertyappl
#2 Posted : Wednesday, December 3, 2008 6:10:06 PM(UTC)
libertyappl
Does the fan in the back of the freezer compartment still run while the compressor is running?
Nat
kayakcrzy
#3 Posted : Thursday, December 4, 2008 5:28:22 AM(UTC)
kayakcrzy
Just be carefull not to order a fan motor until you jump out the defrost thermostat, because the fan is wired through it. The defrost thermostat is located on top of the evaporator coil, and is about the size of a quarter, and has 2 wires coming to it. Cut the 2 wires, in a way that you can wire them back together, and wire them together, and see if the fan comes on. If not replace the fan, if so replace the defrost thermostat. Tom www.applianceeducator.com
kurty_blaze
#4 Posted : Thursday, December 4, 2008 2:10:25 PM(UTC)
kurty_blaze
thanks! i didnt hear a fan so ill try defrost thermostat wire thing first. let ya know!
abadfish66
#5 Posted : Thursday, December 4, 2008 2:20:16 PM(UTC)
abadfish66
Wonder what the reasoning is behind wiring the fan that way?
kayakcrzy
#6 Posted : Thursday, December 4, 2008 4:32:26 PM(UTC)
kayakcrzy
It is really stupid when you think about it. But I would Imagine that they would want the evaporator coil to get cold before the fan runs, so it will blow cold air instead of warm air. Like a furnace, the heat comes on and trips the fan limit switch, and turns the fan on, so cold air won't blow out, the vent, the air would be hot. Tom ApplianceEducator.com
kurty_blaze
#7 Posted : Friday, December 5, 2008 11:52:50 AM(UTC)
kurty_blaze
ok fixed it! its stupid but the cage/bracket that holds the fan in was broken so, we made a new one and it works fine now.
thanks everyone!
