How and what needs to be removed to replace the belt in the Amana washer. I have a diagram but that doesn't help. Thank you for assist....
This one's a toughie. You may just want a professional to do the job. The pump has to come off the replace the belt. The factory-recommended way is to remove the cabinet and turn the tub/transmission/suspension assembly upside down to get to the pump screws.
