up_pilot
#1 Posted : Saturday, January 22, 2011 9:47:38 AM(UTC)
up_pilot
Oven won't heat. Control panel keypad works normally. Pressing Bake -> Start and display turns to Heat, Lo which is normal. Both heating elements are 25-30 Ohms, thermistor is about 1100 Ohms. I thought after taking the rear panel off I would find a thermal fuse, but no. The Tech sheet does not show a thermal fuse. I also don't see one on the control panel, but it's working... Any ideas? Thanks!
#2 Posted : Saturday, January 22, 2011 11:01:49 AM(UTC)
Have you checked your power.
The control board , lights etc run off half the line (120 volts), while the elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
up_pilot
#3 Posted : Saturday, January 22, 2011 12:03:43 PM(UTC)
up_pilot
Wow! I had already flipped the breaker a couple of times, but I repeated flipping it slowly several times and checked the voltages as you suggested. All were present and now the oven is back in service! Thank you!! So I guess for the future, I'll have to determine whether it's just an aging breaker or if the oven still has a problem which caused the trip.
#4 Posted : Sunday, January 23, 2011 4:31:26 AM(UTC)
You are welcome.
Glad to hear you are up and running again.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 11/19/2012 4:38:18 PM(UTC)
Whirlpool oven won't heat (Oven Repair (including Ranges and Cooktops))
by Lamb 8/3/2009 3:09:23 PM(UTC)
Whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by dlchunting 11/30/2008 6:06:41 PM(UTC)
Whirlpool Oven won't heat after self-clean (Oven Repair (including Ranges and Cooktops))
by darladt 11/18/2008 8:48:15 PM(UTC)
Whirlpool Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by jims 10/18/2008 6:49:12 AM(UTC)
Whirlpool Oven won't heat stove works fine (Oven Repair (including Ranges and Cooktops))
by tnearman 10/16/2007 8:35:13 PM(UTC)
