my dryer belt keeps falling off pulley. any suggestions?
Here is your parts breakdown Model CDE9500WHere is how it should look when installed http://www.applianceaid.com/images/belt-config.JPGIs there a fair amount of tension on the belt when it is installed, there should be. If not the spring is weak or the belt has stretched. Check the idler wheel Check to be sure the drum rotates fairly easily |
THIS FORUM IS DEAD!!!!!!! |
