Replacement parts for WHIRLPOOL REX6634RQ0 29`` ELECTRIC DRYER | AppliancePartsPros.comHere is the wiring diagram, see attachment.
First thing to check is the power. The motor uses half the line (120 volts) while the heating coil requires then full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Next check the heating coil, should ba about 10 ohms.
The4n check the thermostats and thermal cut-off, all should be 0 ohms.
If the thermal cut-off is blwn there are other things you should check before replacing it.
