arlacrane
#1 Posted : Friday, January 21, 2011 8:33:55 AM(UTC)
arlacrane
Dried 4 loads of laundry yesterday, 3loads were steaming hot and dry, 4th load was cold and wet. Did and changed nothing different with dryer. Replaced the element 5months ago along with 2 sensors. What do you think went wrong?
#2 Posted : Sunday, January 23, 2011 4:16:51 AM(UTC)
A model number may help others help you.
Check your power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
