Just moved in to a new home and the Dishwasher won't power up. We used it twice and when my wife came back to unload, she found that the unit had shut down. A utensil had fallen through the grate and had jammed the bottom spray arm causing the power to the unit to shut off. I have checked all the fuses and breakers several times and I still cannot get power to the unit. I called Bosch and they gave me choices of repair techs in my area. Is there anything I can look for and possibly fix myself? Thanks for any future help.:)
texastec10
Remove the toe panel and check the wire connection at the dishwasher junction box. Check the "on-off" switch and the door switch.
