Dougrsmith
#1 Posted : Tuesday, December 2, 2008 3:23:09 PM(UTC)
Dougrsmith
Dryer starts but gas does not ignite.:confused:
#2 Posted : Wednesday, December 3, 2008 3:19:38 PM(UTC)
The first thing I would check is the igniter (#717 on the break down diagram). Be careful because this part is very fragile.
Here are the break down diagrams for the GE dryer Model DRL1555RAL
Tappan oven or broiler won't ignite (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2023 6:57:29 AM(UTC)
Viking VDSC365 Grill Burner won't ignite (Oven Repair (including Ranges and Cooktops))
by hippiasrex 8/30/2021 11:08:29 AM(UTC)
Viking range won't ignite when oven is hot (Oven Repair (including Ranges and Cooktops))
by osunick 6/5/2021 5:25:46 PM(UTC)
Whirlpool oven won't ignite unless unplugged and plugged back in. Thoughts? (Oven Repair (including Ranges and Cooktops))
by wbynum 12/20/2018 7:31:13 AM(UTC)
Troubleshooting single burner won't ignite. (Oven Repair (including Ranges and Cooktops))
by mingd 6/28/2017 1:36:23 AM(UTC)
Gas dryer won't ignite after it's warm (Dryer Repair)
Belarus Valleygirl01 9/9/2015 11:47:27 AM(UTC)
Won't ignite, replaced HSI and control (Oven Repair (including Ranges and Cooktops))
by kmkerr23 8/7/2015 2:06:06 PM(UTC)
Oven won't ignite on bake initially but will after using broiler (Oven Repair (including Ranges and Cooktops))
by JeremySDMF 7/15/2015 11:06:20 AM(UTC)
Extra Low Burner won't ignite not the Potentiometer (Oven Repair (including Ranges and Cooktops))
by pcl1194 12/12/2014 1:52:17 PM(UTC)
Carrier 58SX won't ignite (Heating, Ventilation, and Air Conditioning (HVAC))
by bulletsnbrains 11/5/2014 1:38:35 PM(UTC)
Old Caloric oven won't ignite (Oven Repair (including Ranges and Cooktops))
by Alan McRae 6/17/2014 6:22:54 AM(UTC)
Range Burner Won't Ignite (Oven Repair (including Ranges and Cooktops))
by Boatman12 4/11/2013 11:58:00 AM(UTC)
Gas dryer won't ignite (Dryer Repair)
Belarus Nitro itch 3/20/2013 6:37:15 PM(UTC)
Thermador gas oven won't ignite/stay on (Oven Repair (including Ranges and Cooktops))
by 69GTFB 1/28/2013 11:57:57 AM(UTC)
Whirlpool Gas Oven burner won't ignite (Oven Repair (including Ranges and Cooktops))
by dmargosh 12/1/2012 8:09:54 AM(UTC)
