tinkerbell63
#1 Posted : Wednesday, January 19, 2011 5:50:25 AM(UTC)
tinkerbell63
I have a 3 year old Matag dishwasher that no matter what button i press it keeps going back into "Rinse Only" and that is all it does. I turned off the power to it for 5 minutes hoping it would reset. It didnt. I only use it once a week, so its not from overuse. Strange thing is it worked fine before the Tech came in for the recall repair last year. Any suggestions?
Model # mbdtt60awb
#2 Posted : Thursday, January 20, 2011 1:26:32 AM(UTC)
Replacement parts for mdbtt60awb models | AppliancePartsPros.com
Here is the tech sheet, see the attachment.
Could be that the "Rinse Only" button is shorted.
Try running the diagnostics in the tech sheet.
Measure the keys with a meter to see if the "Rinse Only" key is shorted.
File Attachment(s):
MDBTT60.pdf (893kb) downloaded 77 time(s).
tinkerbell63
#3 Posted : Thursday, January 20, 2011 7:18:00 AM(UTC)
tinkerbell63
If it is the Rinse Only button shorted. What part do I need to replace?
thanks for the help.
#4 Posted : Friday, January 21, 2011 2:21:00 AM(UTC)
Take a look in the parts, it is Item 1 in Section 1 (panel).
Not sure if you left a digit or 2 off the end of your model number so check that first before looking up the part.
