Hello,
I am looking for the repair manual for a GE top-freezer refrigerator model # GTS22KBPARWW. On Thanksgiving, the refrigerator was in the 50 degree range, the freezer was fine. I unplugged the fridge, and removed the interior back panel of the freezer, and saw that the coils were all iced up. I did the hairdryer defrost procedure, and put it all back together, plugged it back in, and now it has been running OK for a few days. I would like to have a diagram of the location of all the parts, so I can try to troubleshoot the problem myself if and when it happens again.
Thanks in advance.
You will need to replace the defrost heater, you can go to geappliances.com, and get the breakdown of parts for your refer, then come back here to buy the part as they are a bit cheaper.
abadfish66,
Thanks for your assistance.
