Here are your parts, includes a wiring diagram.
Replacement parts for MAGIC CHEF CYE3004AYW DRYER- ELE | AppliancePartsPros.comDoes the timer work in timed dry.
If not then odds are the thermal fuse (cut-off) (Item 5 in Section 4) is probably blown.
Unplug the unit and the wire to one side of the fuse.
Check it with a meter should be 0 ohms.
You will notice that it also comes with a new hi-limit thermostat.
The hi-limit should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
So they assume it is also no good.
You still have to find out why it blew.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
