bmannell
#1 Posted : Tuesday, January 18, 2011 9:02:13 AM(UTC)
bmannell
This unit appears to work in every way except heating. I have found the diode for the high voltage open. My question is how to check the output side of the high voltage transformer, the primary has continunity. The output has 3 leads what should I read on these?? I have checked the magnatron and have continunity across it.
Thanks Burt
