Probably needs a new motor. Can the motor be changed from underneath the unit with out removing it from it's mount ?:(
Originally Posted by: littletom80 Probably needs a new motor. Can the motor be changed from underneath the unit with out removing it from it's mount ?:(
Originally Posted by: littletom80 Originally Posted by: littletom80 Probably needs a new motor. Can the motor be changed from underneath the unit with out removing it from it's mount ?
