I am looking for replacement parts for my Whirlpool DU941PWKQ1 Quiet Partner II dishwasher. Whirlpoolpartsonline recommends the following part numbers #8193795 (lower dishrack) #8519572 (upper dishrack). The cheapest I've found them is about $120 each. I found some used ones online, but those are still about $100 each after shipping.
I started looking locally in hopes that I can find a broken dishwasher whose racks are still in good shape. Can anyone tell me which other Whirlpool models have dishracks that are compatible with my model?
For example, is upper dishrack part # 3369903 compatible with my model?
Thanks, Rob
I didn't originally notice the Cross Reference and Model information section of the parts pages. I used the model list as a reference and was able to find used replacement racks from a different model that fit my unit.
rob, no help to you. i have the same model. aftet you remove the thumb screw, lower arm assy & cover there is a piece that has 8 torx screws. under that is a single center bolt, does the manual say how to get it off?
