Tappan oven quite old, has an upper oven and lower, range top, all electric. The only thing that works is the oven lights. Any help is appreciated. Is there a fuse I should be looking for ?
The first thing to check is the household electrical to the range. Make sure you are getting 240 volts at the breaker and the plug.
Nat
