gimedaball
#1 Posted : Monday, December 1, 2008 4:41:03 PM(UTC)
gimedaball
My washer isn't draining. After opening the front, it looks like the drain motor
is failing. I'm going to take it out to make sure there's no clog on the other side, but the motor is trying to turn and is having trouble. Could the brushes be wearing out? Is that typical? I see the part on this site that is labeled "Pump and Motor assembly" but the diagram doesn't show the motor part. The part number is AP3160348. Should I just order it and 'hope' it comes with the motor I need?
#2 Posted : Tuesday, December 2, 2008 1:26:33 AM(UTC)
Make sure the motor is getting voltage, if so, order the new motor AP3160348
