Kenmore front loader will not let water in on the first rinse cycle. Water comes in on wash and final rinse O K
Washer is set for cold wash and cold rinse or cold wash and hot rinse.
the easiest way is to start you washer select first cold and cold if water
comes in check on hot water and in that way you can check wich solenoid
is not working if cold or hot. but best bet change the inlet valve assbly.
Check your solenoid inlet screens for blockage.
