Some buttons on my touchpad quit working.
1) I'm having trouble getting to the touchpad. My unit is mounted above my stove. I removed the bottom plate and depressed the two locks holding in the touchpad frame, but could not pry it away.
2) Once I get to the touchpad, how do I verify that it's the touchpad that's bad?
Regards,
Jim
Hi Jim,
If some buttons on the touch pad are not working then the touch pad most likely is bad.
The model number you posted does not come up.
