jsmls
#1 Posted : Sunday, November 30, 2008 6:35:54 PM(UTC)
jsmls
My Kenmore washer will fill and drain; won't agitate or spin. Red lite instead of green comes on if I push spin button. Changed lid switch. No change. Any suggestions?? Thanks, Joe
kayakcrzy
#2 Posted : Monday, December 1, 2008 4:25:41 AM(UTC)
kayakcrzy
If you hear the motor running, in the agitation and spin cycle, then you need a coupler. It is between the motor and the clutch. Tom ApplianceEducator.com
royw64
#3 Posted : Tuesday, October 20, 2009 3:51:48 AM(UTC)
royw64
Be Sure to check the transmission for looseness,this is probably what caused the coupling to break .
my Kenmore washer will not advance to the rinse cycle (Washer Repair)
by Avalon2005 4/20/2016 9:39:27 AM(UTC)
my kenmore washer makes a grinding noise during spin cycle and does not spin (Washer Repair)
by bronco48 10/27/2012 6:49:09 AM(UTC)
My Kenmore washer doesn't complete spin cycle (Washer Repair)
by madlex3n 5/17/2011 7:36:50 PM(UTC)
