dfeldbaum
#1 Posted : Sunday, November 30, 2008 5:51:12 PM(UTC)
dfeldbaum
After hearing a much different noise then normal and the dishwasher not cleaning I have narrowed the problem to this:
The Impeller (AP2109089) is hitting against the housing and as a result is not turning. I can push it in and it will spin properly, but will eventually get stuck again when the motor starts up that cycle and throws it out.
According to the motor & pump diagram I know I need to replace one of the following:
55A (mount or bracket - not sure which is A)
59, 59A (Oring)
7 (Blade)
57 (Drum)
12 (Impeller)
Somehow over time one of the above parts failed causing the impeller to push against the housing and freeze up. I need to know how to remove the above said parts in order to determine which needs replacing. I can remove the little screw holding the impeller, but that doesn't allow me to remove anything.
Hope this is clear. Please advise!
#2 Posted : Monday, December 1, 2008 3:09:59 PM(UTC)
You can find the complete instructions in the Service manual.
Here are the break down diagrams for the Frigidaire dishwasher Model GPDB698JC0
dfeldbaum
#3 Posted : Thursday, December 4, 2008 5:46:42 PM(UTC)
dfeldbaum
Gene,
I appreciate the info as it helped a lot. I narrow the issue down to two parts that I just ordered through Appliance Parts Pros. While trying to get the motor back in (used vaseline) it doesn't seem the Bracket-motor,front sits flush with the housing. What am I doing wrong?
#4 Posted : Thursday, December 4, 2008 9:03:13 PM(UTC)
Some times the plastic tub can get warped. It gives a lot of headache. Keep trying.
