Model : 110.68532700 My dryer has stopped collecting lint except for one small area on the bottom of the screen. It collects in a triangle shaped area, and on the back side of the screen. I recently moved, and noticed when I did, there was some lint trapped in the flexible metal vent hose. Any idea on why this is happening ?
Could find no info using the listed Model Number.
If the clothes are drying as normal. I would suspect the drum seals, your dryer is probably filling up with lint. |
THIS FORUM IS DEAD!!!!!!! |
