When dryer is in use it makes a loud humming noise, have replaced a drum bearing and tension or pulley
Could be the MOTOR going away!!!
Could be the blower wheel. May be dirty OR may have been dirty and some of the crud has come off so now it is out of balance.
Could be a bad motor mount |
THIS FORUM IS DEAD!!!!!!! |
