jbentley
#1 Posted : Sunday, November 30, 2008 10:34:48 AM(UTC)
jbentley
I am needing to replace the water tube in the freezer door because some idiots cut it to remove the door to move it out of the house. Would it be easier to go in from the front or from the inside of the door?
Thanks for your help.
Jeff
kayakcrzy
#2 Posted : Monday, December 1, 2008 4:41:29 AM(UTC)
kayakcrzy
You would have to go into the door from the inside, taking the door liner off. But if the idiots, left some of the line exposed on the bottom of the freezer door, you can buy a 1/4 inch quick connect, to join the 2 lines together. Tom ApplianceEducator.com
