bernd
#1 Posted : Tuesday, January 11, 2011 12:22:52 PM(UTC)
bernd
My GE Dryer MODEL # DBLR333EE2WW RUNS VERY HOT WHEN IT IS BEING USED. I AM GUESSING IT MAY BE THE ONE OF THE THEROMOSTATS. IF IT IS THE THERMOSTAT, HOW WOULD I TEST THEM TO KNOW WHICH ONE IS BAD ONE? THE FOLLOWING THERMOSTAT PARTS ARE LISTED ON YOUR WEB SITE. WHICH ONE COULD IT BE? THANKS, BERND - EMAIL ADDRESS IS bserda@windstream.net
505 UserPostedImage
Enlarge Photo
Safety thermostat - High limit thermostat. L210.
Part Number: AP2042573 made by GE
506 UserPostedImage
Enlarge Photo
Thermostat (4-wire) - L210-30F.
Part Number: AP2044414 made by GE
507 UserPostedImage
Enlarge Photo
Safety thermostat (thermal fuse) - Considered a thermal fuse.
Part Number: AP2042565 made by GE
#2 Posted : Tuesday, January 11, 2011 2:24:14 PM(UTC)
Bernd,
The first thing I would do is clean the dryer exhaust line all the way from the dryer through the vent outlet. Also you may want to take the dryer apart, check the blower wheel and clean all air ducts inside the dryer.
Most common cause for such problem is a restricted air flow.
