my dishwasher suddenly stopped draining and drying and the only cycle setting that seems to even come on is the light cycle...pots and pans and regular cycle make a very quiet hum but don't really do anything....if i run it on the light cycle i end up with half clean dishes and a bunch of water in the bottom of the dishwasher to clean up. any suggestions?
Frigidaire pumps are known to go out. That will most likely be your problem. Of course you want to make sure the drain hose from the dishwasher to the disposal, or the sink drain is not clogged.
Tom
thanks for the heads up :)
