Dryer belt broken, when opened to remove also found idler pulley on bottom of dryer. How do I reattach or do I need to buy a new one. First timer at dryer repair. Thanks
The idler pulley sets in a slot on the base on the right side with the wheel part facing the drum. Here's a breakdown which should help. Model GGQ8858HQ0Nat
