tonye
#1 Posted : Monday, January 10, 2011 8:35:20 AM(UTC)
tonye
:confused:Water drips from water inlet inside wash tub after wash cycle has completed. If I don't get to the machine as soon as it is done with the final spin cycle the cloths will be wet again from the constantly dripping water inside the wash tub. If I turn off the water supply vale, than the dripping stops, but as long as the valve is open it drips constantly. It drips at a slow steady rate, aprox. 1 cup in 5-7 minutes. Why does it continue to drip is it the Water inlet Valve?
coenen
#2 Posted : Thursday, January 13, 2011 1:28:25 PM(UTC)
coenen
I have the same problem with my maytag which is less than 5 years old. Within 1or two hours there is about 1" of water in the tub. Whats up===does anyone know ??????? glenn
