gnit2000
#1 Posted : Sunday, January 9, 2011 1:30:17 PM(UTC)
gnit2000
Hi - It looks like only the "up" bottom of the temperature control is not working. Since the default temperature is 350F, i can not heat the oven to anything more than 350F :( . is there a tip on how to fix it, parts that might be required, and some instruction?
thank you!!! :cool:
kayakcrzy
#2 Posted : Sunday, January 9, 2011 1:53:38 PM(UTC)
kayakcrzy
You could try unplugging the stove, and take all the wires off, one at a time, and then put them back on. Just so you understand, take 1 wire off, and then put it back on, and so on. Sometimes, that might work. If not you will have to replace the control board. The part # is 5701M818-60. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
