I have a bad oven cavity thermistor, but I can't figure out how to get it out of the exhaust duct. It has a metal plate attached to it that is bigger than the opening. Any help would be appreciated. Thanks!
You have to remove the microwave from the cabinet and remove the outer case.
You are welcome. I'm glad you were able to fix it.
