95bravo
#1 Posted : Saturday, January 8, 2011 5:15:58 AM(UTC)
95bravo
how do I change the idler arm pully.
sidfink43
#2 Posted : Monday, January 10, 2011 10:00:46 AM(UTC)
sidfink43
If you will take off the lower service panel (two screws) you can then take out two screws that hold the front panel on and it will swing out from the bottom and come off. Disconnect the switch wiring, and take out the front support part and drum and you can access the pulley.
