ggeisen
#1 Posted : Saturday, January 8, 2011 4:57:03 AM(UTC)
ggeisen
All cycles seem to function normally except the main wash cycle just runs and runs and runs until I press cancel to end the cycle.
Is there a dirty sensor in this model that may need cleaning???
ggeisen
#2 Posted : Saturday, January 29, 2011 9:47:38 AM(UTC)
ggeisen
Just wondering if anyone has an idea ... everything else about the diswasher works.
#3 Posted : Sunday, January 30, 2011 12:44:00 AM(UTC)
Replacement parts for WHIRLPOOL KUDL02FRSS2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Here is the tech sheet, see attachment.
Often this is a heater problem as the unit cannot reach the temperature set point.
But this unit should give you an error.
I would start with checking the heater, the hi-limit thermostat and the thermistor if your unit uses one.
Also check that the water entering the unit is at least 120 degrees F.
File Attachment(s):
KUDL02.pdf (251kb) downloaded 3 time(s).
