My electric Roper dryer will produce only low heat running with clothes inside(on high setting). exhaust heat is 110 degrees f. with clothes inside. The interesting thing is with no clothes the heat cycles up to 165ish on high setting. Element is not grounded and comes in at 9.1 ohms. Please help.
Come on guys, surely someone has some input on this solvable problem.... ;)
