Help!! Received the needed part - the door latch but can not unplug the old latch from the wire connectors. Can't find any documents that explain how to do this. Can you help me??
Gloria
This may help http://appliancedigest.com/index.php?/files/file/474-16021814-maytag-jetclean-ii-dishwashers-service-manual/You may have to join the sire but it is free and is a great place for appliance DIYer info. If the new latch does not have the switches remove the switches from the old latch and install them on the new unit. Do not bother trying to get the connectors off the switches. If the new latch has the switches get a flat screw driver of the correct width and place it between the switch body and the connector and then twist the screw driver to force the connector back off the switch. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the information. Will try it later today.
