Gamla33
#1 Posted : Sunday, October 7, 2007 6:41:32 AM(UTC)
Gamla33
Over the last few days I've noticed that some of the food in the fridge section has been spoiling. Last night I noticed a somewhat loud "rumbling" type sound that won't stop unless I open the fridge door (it sounds like a fan winding down). When I close the door the sound starts up right away.
The freezer seems to be working fine, however the firdge section barely cools at all. Gaskets are fine and airflow outlests are not blocked. Any help would be much appreciated.
thank you
#2 Posted : Sunday, October 7, 2007 11:15:36 AM(UTC)
You have a bad evaporator fan or one jammed by ice. Remove freezer back panel and check. Also, your model # is wrong, please check.
Please post results.
