rgrandmaison5@gmail.com
#1 Posted : Wednesday, January 5, 2011 8:18:40 PM(UTC)
Hi I have a Kenmore Dishwasher serial number 665-16354300.The dishwasher keeps running on the wash cycle, have to manually stop it or it runs continuously. Any ideas?
#2 Posted : Thursday, January 6, 2011 12:21:56 AM(UTC)
Replacement parts for 665-16354300 models | AppliancePartsPros.com
Here is a tech sheet, see the attachment.
As you can see from the tech sheet it could be that the unit is trying to achieve a water temperature set point but is not getting there.
Could be a bad heater, high-limit thermostat, thermistor or control board.
I am assuming that every thing looks normal.
Try a cycle where no heat is require. Does it now complete t he cycle?
If yes then the above is probably happening.
#3 Posted : Thursday, January 6, 2011 2:58:36 AM(UTC)
What is the Thermister? What does it do?
#4 Posted : Thursday, January 6, 2011 3:24:39 AM(UTC)
It is a solid state device that changes resistance with temperature (lowers resistance as temperature rises).
Tells the unit what the actual temperature is.
