Microvave, does not heat up any thing, yet it sounds like its working. Yet Turbo bake, Grill and Combination all work. Checked 2 fuses on power supply board for continuity, Ok, is there a other fuse ? to check ? wiring dia, would be of help please.. I just need to be pointed in the right direction.
TIA, Snowey... :confused:
:) Sorted loose connections on magnetron,
