My control pannel shows 21 and won't change unless I reset the power
Gene sometime it resets and works and sometime I have to leave it shut down for a while to get it to reset.
It will work as I said then sometime I have to leave it off for a while and then it will reset and work again
Quote:...My control pannel shows 21... Originally Posted by: Gene  ...What does it do at this point? Does it wash, drain or stays silent?... I still need you to answer this question. Gene.
Originally Posted by: Gene  When I get it ti reset it works it does everything wash drain dry it totally works and every now and then it goes back to 21 and I have to reset it again and then it will work again totally for a while
Sounds very unusual. It can be a loose connection somewhere as well as a bad control board.
If it does it not very often I would keep use the dishwasher until it will die.
