stvokc
#1 Posted : Wednesday, January 5, 2011 6:14:04 AM(UTC)
stvokc
Gas Drying Cabinet MCG8000AWW
Will run just fine for on Air Dry cycle.
When you run Timed Dry it runs just fine for about 6-8 minutes. Then it flashes the LED lights while a blank screen(time) for a few seconds. Then the screen has PF code in it meaning power falure and LED's stop flasing.
I reset it to factory settings and tried again and this time after 8 minutes the LED flashed and the screen (time) was just blank. I could not get it to stop flashinfg the LED no matter what I pushed. I even unplugged it for 30 seconds and plugged it back in and it would not stop flashing the LED's. I tried unplugging again for a couple of minute then plugged back in and the LED would just flash with a blank time. So I unplugged it again for 30 minutes and plugged it back in and NOW it it starts up fine again.
I can't understand why it would run fine on Air Dry cycle and not on Timed Dry. Also it takes about 6-8 minutes on Timed Dry Cycle before it acts up.
Is it the Relay Board or the Logic Control Board or some sensor?
.AOLWebSuite .AOLPicturesFullSizeLink { height: 1px; width: 1px; overflow: hidden; } .AOLWebSuite a {color:blue; text-decoration: underline; cursor: pointer} .AOLWebSuite a.hsSig {cursor: default}
