I have a Speed Queen front load washer, every once in awhile the door will open on its own during a wash cycle. Could it be a door latch assembly or possibly a control board or motor control board? I check the door several times when the washer is running and it is always in the lock position and will not open. This is a very frustrating problem as when it does happen water goes everywhere. Any suggestions?????????
