I have a GE wall mount oven that will not start. At first the start button would not work, then the entire display lit up. I replaced the control and my display is back, but the start button will still not function. All of the other buttons work fine, I can set the temp, the time, the time delay, everything but start the darn thing. :mad: Is it the panel, or am I just missing something?:confused:
Most likely the problem is a bad keypad which is a part of the control panel. - The part number for the control panel is AP3183407 Gene.
