Link05
#1 Posted : Saturday, January 1, 2011 4:45:51 AM(UTC)
Link05
AP4366551 broke, unit wouldn't drain. Removed AP2910020 and cleaned out broken pieces. What is the little black flap in there for and how do I know if it is working propperly?
ApplianceJunk
#2 Posted : Saturday, January 1, 2011 6:38:23 AM(UTC)
ApplianceJunk
The black flap acts as the check valve. It keeps water from coming back down the drain hose and entering the dishwasher.
The flap opens up when water is traveling out of the dishwasher and then the flap seals closed if water tries to travel the other way, into the dishwasher through the drain hose.
Mystery Ball Check Valve Shows Up In GE Dishwasher Pump (Dishwasher Repair)
by lokar 9/29/2021 8:04:19 AM(UTC)
Drain check valve (Dishwasher Repair)
by rubensd73116 7/10/2017 12:58:28 PM(UTC)
GE Dishwasher Check Valve (Dishwasher Repair)
by TAKANE724 8/7/2014 3:01:24 PM(UTC)
Freezer dripping into fridge, Can't get to drain tube check valve?? (Refrigerator & Freezer Repair)
by g20zoom 3/1/2014 6:57:48 PM(UTC)
Rubber check valve (Dishwasher Repair)
by keyvie 10/14/2013 8:18:25 AM(UTC)
check valve in drain hose? (Washer Repair)
by eschutt 7/15/2013 4:49:38 AM(UTC)
Ldf6920 Check valve motor (Dishwasher Repair)
by Katzelff 10/9/2012 12:19:44 PM(UTC)
Cannot unscrew check valve (Dishwasher Repair)
by sdhmed 7/10/2012 4:35:25 PM(UTC)
GE fridge water filter check valve leaking (Refrigerator & Freezer Repair)
by pdub1970 6/7/2012 9:29:44 AM(UTC)
Neptune with a bad drain pump/check valve? (Washer Repair)
by petrichm 5/6/2012 7:44:53 AM(UTC)
Replacing Check Valve (Dishwasher Repair)
by Bill46 3/23/2011 4:29:34 PM(UTC)
What is the function os a CHECK VALVE? (Dishwasher Repair)
by jerryandtabatha 8/23/2010 6:44:13 PM(UTC)
Could the piston & nut assembly for check valve be my problem? (Dishwasher Repair)
by stp57 1/17/2010 9:28:02 PM(UTC)
Check valve replacement (Dishwasher Repair)
by marc74 11/18/2009 11:45:24 AM(UTC)
clear silicone sealant in drain check valve (Dishwasher Repair)
by pchristenson 11/8/2009 9:56:20 AM(UTC)
